Studio Run VS Uipath Robot Run 차이 ( What's the difference between running as a studio and running as a bot? )
스튜디오로 Running 하는것과 Robot을 통해 Running 하는것은 어떤 차이가 있나요??
( What’s the difference between running as a studio and running as a bot? )
Hi @JasonL
UiPath Studio:: Studio Designer is the perfectly intuitive environment where anybody can model automation visually, without code. A powerful recorder literally builds automation by watching
you work and a rich library of template activities will get you moving fast and easy.
UiPath Robot executes processes with perfect accuracy. It can run assisted, automatically executing tasks under your employees’ control and supervision, or unassisted, processing high-volume work independently from human interaction.
cheers :smiley:
Happy learning :smiley:
ahh okay. I see.
Thank you guys.:smiley:
@JasonL
No Worries Happy to help :smiley:
cheers :smiley:
