…thx, will check
I meant , I have edited the Config file slight_smile
But it is not working for me
@PaviniDilip yes I have created the the Orchestrator Queue
Thx!
You should also create a robot on the pane?
I got it now added to th queue
Thanks for the Tip I also had to Pass the Queuename in this format “Queuename” as Sreekanth mentioned .
Now the Dispacher is next , thx
I meant the Performer is next ,…
Hello,
I am stuck in the UiDemo_Walkthrough. whenever I am trying to run the Initallapplication its showing an error as "Object reference is not set to an instance of an object ". I have created the asset named UiDemoPath.
Can anyone help me out with this issue?
Hello Mr Ravi,
I am not an expert in .net coding. Is it possible for you to share your workflow with me? So that I can understand ? Cz not just this issue, when m opening the main file and running it with the
filename=in_Config(“UiDemoPath”).ToString in initallapplication
The application is not opening. UiDemoPath is Already saved in asset in orchestrator.
And y is it not showing the value I donot know.
Hey guys,
Is there a video walkthrough of the Uidemo - level 3?
I followed UiDemo WalkThrough Document …I did upto Dispatcher and when i ran the Sequence Dispatcher_UploadQueue i am getting the below error
Get Transaction Item: KibanaDemoQueue does not exist. Error code: 1002.
In the document it is no where mentioned about Kibana Demo Queue under the sequence. So why is it going and checking Kibana setup. How the Items will get added to the Queue Dispatcher.
Bala
