Hello Friends, I have this String: “123456”
And I need put a “.” ever in middle of this string.
Exmp:
123456 → 123.456
213640 → 213.640
354156 → 354.156
help pls, thx!
Exmp:
123456 → 123.456
213640 → 213.640
354156 → 354.156
help pls, thx!
Hi @Diego_Pin
You can try this inside the Assign activity:
String Input = "123456"
Input.Insert(3,".")
You can also have the number of places as a separate integer and use it as required to make it dynamic in nature.
Cheers!
addDotInNumber.zip (2.2 KB)
Please find the attached workflow.
Hopw this will helps.
Mark as solution if it works
