String Split Accordingly Using Split
I have the following text:
I want to extract separately:
And:
I used:
Split(information, “-----------------------------------------”)(2).ToString
But it generated:
I dont want the last text.
Thank You
Please Advice
@Hurmet_Noka
You can place a break point and check the values you are getting
As you used the index as (2), instead use (1), you are getting the result correctly
Thanks
I need this text:
@Hurmet_Noka
Replace Outbound Flight Information text with empty.
     output = input.Replace("Outbound Flight Information","")
Hi
you are almost done
for first part use this in assign activity
str_part1 = Split(Split(information, “Inbound Flight Information”)(1).ToString),“Outbound Flight Information”)(0).ToString.Replace("-----------------------------------------","")
and for second part like this
str_part2 = Split(Split(information, “Inbound Flight Information”)(1).ToString),“Outbound Flight Information”)(1).ToString.Replace("-----------------------------------------","")
Cheers @Hurmet_Noka
Thank You So Much!
Respect
