String conversion issue
Hi, Can you please tell me I want to store the FC type into genericvalue type. Can you please
Right side is FC type and Left side is Generic type
@lakshman
@balkishan
Declare OrderNum variable as string and then try again.
OrderNum = orderNo.Tostring
That I did bro, Just tell me will it give the value na, means no impact on the value.
@balkishan
Try to print the value after that assign activity using Message Box activity. Till now I didn’t work with FC type variables. So no idea on this.
@lakshman did you work on Abbyy bro?
@balkishan
I didn’t used till now.
