Hey,
Lets say I have the string “Asanka El Camino” or “Asanka Camino”
Looking for the output of
“El Camino, Asanka” and “Camino, Asanka”
Keep in mind original string could be anything and could be 1 to 3 words.
Hey,
Please try this syntax
strText = “Asanka Camino”
String.Join(" “,Split(strText,” ").AsEnumerable.reverse.toarray)
Output = Camino Asanka
Thanks!
What about for “El Camino, Asanka”?
Can it be done in one? Say if its Asanka Camino or Asanka El Camino?
@Asanka
Assuming this
test=“Asanka Camino” or “Asanka El Camino”
test.Substring(test.IndexOf(" "))+","+test.Split(" "c)(0)
Hi @Asanka
I am confused by what order it should join
One case it is joining by reverse other by some other way
For “El Camino, Asanka” use String.Join(" “,Split(strText,”,“).AsEnumerable.reverse.toarray)
For “Asanka Camino” use String.Join(” “,Split(strText,” “).AsEnumerable.reverse.toarray)
For “Asanka El Camino” we should have atleast have 2 spaces between asanka and El camino use String.Join(” “,Split(strText,”
Hey it worked! Thanks so much!
