Below is the example
Example
a,b,c,d,e,f
Output
Part1 - a,b,c
Part2 - d,e,f
Thanks
Example
a,b,c,d,e,f
Output
Part1 - a,b,c
Part2 - d,e,f
Thanks
we do have more options for this. Some more details can help for selecting one choice out of many
In the mean while a quick/dirty simple one:
And when we have this length of not length is a multiple of 2:
thats why we used the \ for the integer division
Any idea , how we can have n equal parts .
With the above solution it is giving 2 parts
Hi @Hitesh1 ,
I believe we need more details for this to be concluded.
From your Input String and Output Requirement, we have the Below Two Possible Outputs :
Output 1 = {"a,b","c,d","e,f"}
Output 2 = {"a,b,c","d,e,f"}
Would You explain as to what is the Output that is required for your case and Why so as to use the Logic.
If number of the words in string is greater than 200 then we may need 3 equal parts and if no. of words< 200 words then 2 equal parts
I have to make decision based on words of string
Hi @Hitesh1 ,
Could you give this workflow a try?
Enumerable.Range(0,CInt(arr_items.Count()/int_itemCount)).Select(Function(s) arr_items.Skip(s*int_itemCount).Take(int_itemCount).ToArray).ToArray
Iβve added both examples, so donβt get confused between the more and less keywords, its the same code but with both scenarios.
SplitArrayIntoSizableUnits.xaml (8.4 KB)
Kind Regards,
Ashwin A.K
Hi Hitesh,
You can you skip and take functions as per your requirement.
Please check below xaml file
stringFormat.xaml (7.1 KB)
Thank you,
Debakanta.
Sorry, but I am not able to get where to pass my string having n number of words
Hi @Hitesh1 ,
Yep, I overcomplicated it, my mistake!
Here is a simpler workflow β
SplitArrayIntoSizableUnits_v1.xaml (6.2 KB)
Kind Regards,
Ashwin A.K
Thanks for answer. I tested this for 6 words , it is not working as expected
input {βaβ,βbβ,βcβ,βdβ,βeβ,βfβ}
If(arr_items.Count>5,3,2) β It should create 3 parts a,b c,d and e,f
input {βaβ,βbβ,βcβ,βdβ}
If(arr_items.Count>5,3,2) β It should create 2 parts a,b,c and d,e,f
Hi @Hitesh1 ,
Could you verify once more?
For six item array β
For five item array β
The last item is getting omitted, but that can be fixed using a Math.Celing function like so β
Enumerable.Range(0,Cint(Math.Ceiling(arr_items.Count()/int_itemCount))).Select(Function(s) arr_items.Skip(s*int_itemCount).Take(int_itemCount).ToArray).ToArray
SplitArrayIntoSizableUnits_v2.xaml (7.9 KB)
Kind Regards,
Ashwin A.K
