I am trying to take specific words from my pdf to record them on a data table en fill a form with.
This is my workflow, which works at the moment:
But , I would like to repeat the process without developing the entire workflow again and again… I’ve tried with the fonction while, for each… but none worked.
Eg: with the split(5) I get the Lastname:
I want to get with Split(6) the Name… with Split(7) the adress and so on …
Thank you very much for your help!
Unless I am understanding the issue wrongly, I do not think that you have to repeat or loop the process. After splitting you can assign all variables at once:
Assign Lastname = splitdata(5)
Assign name = splitdata(6)
Assign address = splitdata(7)
For Each split you need to assing Ubound for max count.
Example:
MaxVal = UBound(SplitOutPut).toString
This will give you max segments of the split condition.
Then you can loop till MaxVal so that it will become a dynamic split.
In side the Loop you can increase the count.
Example Split(i)
inside the loop i=i+1
