per my testing, when manual, it appear in the foreground and can click, when use Robot, this window disappear, cannot get it and cannot click “Yes” button.
I had put my excel as attachment in the post body, can you test per your computer?
Can you run and stope the process on that particular step and send the whole screen SS including taskbar?
Don’t indicate on yes button instead indicate on whole popup
Yes ofc you can also do that but SS should be with the taskbar and i want to see that panel
Hi @Lori
If the element appears on the screen only it will return true other wise it will return false only in element exits output!
How the element exist works?
Element exists activity
If elements exists
then → click save button
Else–>Leave
Regards
Addition one more, the check box “Show data losing waring when editing comma delimited files(*.csv)” setting did not appear the robot machine, however, when save xls as csv file ,that window can pop up every time.
This setting checked on my computer, when I save xls as csv manual, will appear below information as attachment
If Robot can get that window, then → click save button, Else–>throw exception.
Per the testing, Robot cannot get that window, and always return false.
Hi @Lori
You can try with the below steps.
Surround the sequence with try catch.
Element exists
Then -->click save button
else–>add the throw activity and mention the exception as New System Exception
Catch we may able to get the exception!
Regards
Hi @Lori
You need to attach window that you are using before click and click should be inside the do container of the attach window!
And more over try catch will not work in debug mode!
Regards
@pravin_calvin
losing two attach activities methods in the current project, however, when I create new project use “Robot Enterprise Framework” template, the new project can find that two activities. how can I solve this issue?
Hi @Lori
We can try enabling the from the activities filter by enabling the show classic!
Activity panel–>filter option------>show classic
Regards
That did not solve my title description problem, just help me find two activities, if anyone can help me solve the title description problem, I’d glad to make it solution and close the post, anyway, thanks for your warm-hearted help.
@Gokul001 @pravin_calvin @THIRU_NANI
Thanks for all kindly help which has given me a lot of inspiration, I have solve this problem per other method!
