Hello all,
My objective is to manipulate a pivot table in one excel using invoke code. One of my issues relies in filtering one of the fields. For this i’m using the following :
Dim excel As Microsoft.Office.Interop.Excel.Application
Dim wb As Microsoft.Office.Interop.Excel.Workbook
Dim ws As Microsoft.Office.Interop.Excel.Worksheet
Dim p_ws As Microsoft.Office.Interop.Excel.Worksheet
excel = New Microsoft.Office.Interop.Excel.ApplicationClass ‘create the instance of excel workbook’
wb = excel.Workbooks.Open(reportPath) ‘Open the excel the file’
excel.Visible=True
ws=CType(wb.Sheets(strSheetPivotTable),Microsoft.Office.Interop.Excel.Worksheet) ‘select a sheet and activates’
ws.Activate
'Select pivot table ’
Dim oPivotTable As Microsoft.Office.Interop.Excel.PivotTable=Nothing
oPivotTable = CType(ws.PivotTables(“PivotTable1”),Microsoft.Office.Interop.Excel.PivotTable) ’ Select Pivot Table
oPivotTable.ClearAllFilters
‘Creation of pivot Fields’
Dim oPivotField As Microsoft.Office.Interop.Excel.PivotField=Nothing
oPivotField=CType(oPivotTable.PivotFields(“SP Cleaned”),Microsoft.Office.Interop.Excel.PivotField)‘Put the column “Cost Center” on the square “Column” of the Pivot’
oPivotField.Orientation=Microsoft.Office.Interop.Excel.XlPivotFieldOrientation.xlPageField
oPivotField.CurrentPage = StrSalesProduct
The StrSalesProduct is one argument with direction “in” and with string type.
I’m able to do this if StrSalesProduct was a int32 i could make .tostring and it works but for a string I’m allways having this problem :
I’m not understanding why this is happening for the string argument. What i’m doing wrong ?
Thanks in advance.
[SOLVED]
