Solution Architecture Trainingl Solution design: create SDD and technical testing plan
All,
I am at lost. Technical prequisite under solution architecture training shows to have an ACME #1 and ACME #3 account but not sure how to use it? In the training module I need to finish the exercises which includes flow charts etc. but not sure where and how to create them either. This is kind of puzzling and will need some help from someone who has completed this training.
Thanks in advance!
Hi @ayoub.siddiqui
You can access ACME System 1 here:
Simply create an account for free.
I think ACME System 3 is something you can download from the same site..?
But not sure :sweat_smile:
Regards
Soren
Hi @ayoub.siddiqui,
You need to create an account on https://acme-test.uipath.com. Once done, you can proceed with the required steps for ACME 1.
For ACME 3, navigate to:
ACME System 1 - Log In then Click ‘Download’
(or refer to the attached image).
For flowchart creation, you can use tools like MS Visio or draw.io.
Thanks!
Hello,
I have created ACME 1 account and downloaded ACME3. Where can I find instructions on using them? I don’t recall seeing any instructions besides how to download and create account.
Other part of my confusion is the flow chart, where in the training can I find a step by step process?
The instructions for ACME 1 and ACME 3 are available in the RPA Developer Foundation/Advanced course. You can check the Practice Project sections, where the detailed requirements (PDD) are explained. The flowchart is not provided step-by-step; you are expected to design it yourself based on the requirements, you can use MS Visio, Draw.io or any other tool to design the flowchart.
Is there a possibility for you to share the link to the RPA develper foundation? I started off with " A day in the life of an an RPA" https://academy.uipath.com/courses/a-day-in-the-life-of-an-rpa-developer-
Thanks for the continuous support you have been providing!
Hi @ayoub.siddiqui,
Here are the links:
Developer Foundation: https://academy.uipath.com/learning-plans/automation-developer-associate-training
Developer Advanced Professional: https://academy.uipath.com/learning-plans/automation-developer-professional-training
If this helps, please consider marking it as a solution so it can help others as well.
Thanks!
