AgentHack submission type
Enterprise Agents
Name
Gabriel Moreno da Luz
Team name
Starta Team
Team members
How many agents do you use
One agent
Industry category in which use case would best fit in (Select up to 2 industries)
Other sector
Complexity level
Intermediate
Summary (abstract)
We automated the entire contract review process from email reception to structured analysis using UiPath Agents, Maestro, and DataFabric.
No more manual reviews. Attachments are processed, analyzed, and responded to in a fully consistent and scalable way.
Perfect for legal, procurement, and compliance teams.
Detailed problem statement
Manual contract analysis is a slow, error-prone, and resource-intensive process.
In many companies, contracts arrive by email and must be manually opened, read, and interpreted by legal or compliance teams. This involves:
Opening and reading long PDF files, sometimes with dozens of pages
Identifying key clauses, such as payment terms, abusive conditions, and legal risks
Extracting parties’ information (names, CNPJs, roles)
Summarizing key points to support decision-making
Responding to the requester with insights or approval steps
This repetitive process:
Wastes valuable time from highly qualified professionals
Is vulnerable to human error and oversight
Creates bottlenecks in procurement, legal and compliance flows
Lacks consistency in the way contracts are reviewed and interpreted
Doesn’t scale with the volume of incoming contracts
The bigger the company, the worse the impact.
Detailed solution
Our automation was designed to solve a repetitive and high-risk problem: manual contract review. We built a robust, modular, and scalable architecture using UiPath, Maestro, DataFabric, and Gmail integration. Below is a breakdown of the process:
Triggering the Process
The automation is triggered by a Gmail Trigger. When a new email arrives and the subject contains the word “CONTRACT”, the process is initiated automatically. This eliminates the need for manual monitoring of inboxes. -
Attachment Validation
The first step of the workflow is to verify whether the email contains an attachment:
If no attachment is found, the system immediately replies to the sender with a polite notification informing them that the contract was not attached.
If an attachment is found, the automation proceeds to the next step.
- Creating a Record in DataFabric
A new record is created in a DataFabric entity designed specifically for contract analysis. This record includes:
The contract’s name (extracted from the email or attachment)
A placeholder field for the file itself
This structure allows centralization and tracking of all contract processing activities.
- Handling File Uploads
Because UiPath has a known limitation of 10,000 characters in input arguments, sending large PDF files directly is not viable.
To solve this, we developed a separate workflow responsible for:
Downloading the attachment from the Gmail message
Uploading the file directly to the DataFabric entity
This decouples the file management from the main flow and ensures the solution handles large files reliably.
- Executing the UiPath Agent
Once the contract is stored, we trigger a UiPath Agent, which is configured to:
Retrieve the contract content using the DataFabric record ID
Perform text extraction and preprocessing
Identify key legal and business information in the document:
Abusive or risky clauses
Payment terms and deadlines
Names, roles, and tax information of involved parties
The agent outputs a structured HTML summary with all extracted insights.
- Generating the HTML Summary
To ensure consistency in the output, we created a predefined HTML template using UiPath Contexts. The template includes:
Header with contract information
Highlighted key points and risk areas
Structured formatting for easy reading
A visual score or status for decision-making
- Replying to the Original Email
The final step of the process is sending an automated email back to the original sender. This email contains:
A summary of the analysis
The structured HTML with the detailed insights
Optional next steps if configured (e.g., request approval, forward to legal, etc.)
- Orchestration with Maestro
All workflows (trigger, validation, file handling, agent execution, and email response) are orchestrated using UiPath Maestro, which ensures:
Clear monitoring of each step
Error handling and retries
Seamless data flow between components
Scalability for handling high volumes of contracts
Demo Video
Expected impact of this automation
The implementation of this automation brings measurable, high-impact results across multiple dimensions of business efficiency, cost savings, and risk reduction.
Drastic Reduction in Processing Time
Manual review of a contract used to take up to 2 full working days (approximately 960 minutes) including reading, identifying critical clauses, summarizing the content, and responding. With the automated workflow, this time was reduced to 2 minutes per contract — a 99.8% time reduction.
This means contracts can now be reviewed in near real-time, enabling faster procurement cycles, quicker legal validation, and overall business agility.
Significant Cost Savings
With a team of 7 professionals each earning R$ 45/hour, and a saving of 958 minutes per contract, the cost saving per document is approximately:
R$ 718.50 per contract
Assuming 70 contracts per month, this results in a monthly saving of R$ 50,295.00, or over R$ 600,000 per year, without compromising accuracy or quality.
Productivity Gains
The automation frees professionals from repetitive, manual tasks, allowing them to focus on strategic decision-making, legal analysis, and exception handling. This improves:
Team efficiency
Job satisfaction
Organizational output without increasing headcount
Standardization and Consistency
Using UiPath Contexts and a predefined HTML template ensures that every contract analysis follows a consistent structure. This:
Reduces subjective interpretation
Ensures equal treatment of similar contracts
Facilitates auditability and compliance
Scalability and Volume Handling
The modular architecture using UiPath Agents and Maestro allows the process to scale horizontally. Whether it’s 70 contracts or 700, the system can handle the load with minimal human intervention, making it future-proof for business growth.
Improved Data Security and Traceability
By storing contract data and documents in DataFabric, the solution ensures:
Centralized, secure storage
Controlled access to sensitive documents
Complete traceability of who triggered, analyzed, and received each response
Strategic Business Value
Faster contract processing means faster deal closures, better negotiation positioning, and reduced operational bottlenecks in legal, procurement, and compliance teams. This contributes directly to:
Operational excellence
Business scalability
Competitive advantage
UiPath products used (select up to 4 items)
UiPath Agent Builder
UiPath Automation Cloud™
UiPath Data Service
UiPath Integration Service
UiPath Maestro
UiPath Orchestrator
UiPath Robots
UiPath Studio Web
Integration with external technologies
Gmail
Agentic solution architecture (file size up to 4 MB)
Sample inputs and outputs for solution execution
It’s located in other resources.
Other resources
Input example:
output example:
Presentation:
Other Attachments:
