Siltra, problem to send FDI document
Hello,
I am developing a process in Siltra (java application). But I’m having trouble sending FDI documents.
As seen in the image, when I click on “Envío/Recepción” Button, the program is blocked (in the image it is blocked, the button is duplicated).
And also I have no way to close the program (neither by killing the process with UiPath or manually from the task manager).
This does not happen when the process is done manually.
Anyone can help me? Thank you!
Hi @ereinapo
There is a fix for SILTRA applications that has been added to UiAutomation 22.7-preview package. Please try it and check if it solves your issue.
