Settings modifications to consider for interacting with a legacy application originally built for Internet Explorer to open correctly on the Edge browser.
Settings modifications to consider for interacting with a legacy application built for Internet Explorer to open on the Edge browser.
Resolution:
  1. Open Microsoft Edge and click the 3 dots in the top right.
  1. Select the 'Settings' tab.
  1. Select the 'Default Browser' tab in settings.
  1. Click the drop-down arrow and select 'Incompatible site only (Recommended)', then click the 'Add' option. Also, ensure that the 'Missile' option is set to 'Allow'.
  1. After hitting the tab button, you are going to 'add'.
  1. Next, go to the Control Panel and select 'Large Icons' from the top right corner.
Note: The Control Panel can be located by searching for 'Control Panel' in the bottom left-hand corner of the screen.
  1. Next go to 'Internet Options'.
  1. In internet options go the 'security' tab and then the green check mark labeled' 'trusted sites'.
  1. Select the 'sites' option and then from there add to the list of trusted sites.
  1. After following these steps, the scanning option in Edge should be available for use.
  • Contact UiPath Product Support: If the issue persists, create a UiPath Support ticket for further troubleshooting!
  • Ensure to provide or attach the following list of details in the ticket being created: adding screenshots of any errors encountered would be helpful for diagnosing the issue in the created ticket.
