Hi ,
I have followed below video but it is not working. I have given required permission to the user and checked the Http connection in swagger as well. Everything seems fine.
Hi ,
Hi @sneelavannan ,
With MS team, I think it is possible to use activities like click and type into from UiPath
I used to do the process of sending reports to the channel without using a Webhooks
I would like to send the status of jobs via web hooks
I understand that after completing the process it will send a success or false message to channel
This can be done even with webhooks or activities
your cloud flow is not triggered or some error is throwing ?
Could you share some screenshot without sensitive information?
Hello,
Check if there are any firewall or network restrictions that might be blocking the communication between UiPath Studio and the Power Automate service.
Check for any network restrictions or firewall rules that might be blocking the outgoing requests.
After saving power automate flow, we could extract the full http request and use it inside web hooks to trigger the flow
