Awesome! I will mark this one as Completed
See here for a link to the page @gheorghestan is talking about:
https://cloud.uipath.com/portal_/resourceCenter
when i follow the link
BTW. THANKS for the release, sure it will help a lot of users! (including me)
Thanks for the report, I think our team fixed it right away
How is this suppose to be run/installed? Don’t see any documentation?
When trying to open UiExplorer.exe absolutely nothing happens, maybe I am missing something?
Hi @Petar_Soce
Could you double check your antivirus logs in case it was blocked?
Otherwise, could you check if the previous version works for you?
Yes. Downloaded previous version 20.4.2 and that one works. Thanks
Hi Maciej,
Can you request an update of the UiExplorer Standalone Tool. We just updated our enterprise platform to 2021.4.3 and the standalone 2020.4.2/3 will not communicate with the latest plugin for EDGE - Chromium Based. Keeps saying we need to install extension even tho it’s installed and active in the browser as we can see the icon, also settings is locked to active so no one can disable or uninstall it (deployed through GPO)
Now even better, integrate it into the new assistant, see that would be awesome so we don’t have to go looking for the tool in resource center
Hi @Rasmus_J
It looks like the latest version is actually already available:
It’s a really cool idea, I’ll save it for our team to consider
