okalinic
(Okalinic)
1
Hello.
I have a problem when trying to Repair selectors on the robot machine
I found some suggestions to desable IE enhanced mode, but there is no suggested option in the Internet options
When I run the process, nothing happens, there is no possibility to find selectors that are used to reach window elements.
Does anyone have some other idea how to solve the problem?
Hi @okalinic ,
Can you try check the below options
Open UiPath Studio.
Go to Home > Tools
Make sure the UiPath Extension for Internet Explorer is installed.
And also Go to control panel → Programs and Features → Go to Turn windows feature on or off and select Internet Explorer 11 option checked.
Thanks,
Pallavi
Hi @okalinic
Could you please check if it is restricted by your organization via Group Policy?
