Selector Repository for Web Automation and SAP Automation
Hi Developers,
We are trying to automate a Web Application along with SAP. Our requirement is to create a repository where we need to store all the Selectors of the UI Elements (both Web & SAP) so that we can retrieve the required selector for the workflow and easily maintain the selector base.
Please specify a best approach in creating and maintaining the selectors repository.
Hari
HI @harishankar.r
Good day,
Are you using RE-Framework?
If yes then you can store the dynamic values of selectors in the Config.xlsx, else you need to create a config file.
Hope this helps you !!
Thanks
