I have 3 process with single bot main.xaml. like process A, process B, Process C.
Process A,B,C has different “xaml file” with “.screenshot”. but I can’t see the informative screenshot of an Activity inside my process of A.xaml , B.xaml and C.xaml.
I know UiPath will take parent .Screenshot Folder inside the root of our project. but i want separate folder .screenshot reference for process(A.xaml,B.xaml,C.xaml) with single project(Main.xaml).
In RE Framework you have the TakeScreenshot workflow, which accepts in_Folder as parameter. You could include this in your project, and call it in case of error passing the desired in_Folder argument.
Thanks for your reply, But I’m talking about .screenshot folder not “TakeScreenshot” Activity. Can you please read my above query clearly. Hope my sound is good .
This’s workaround is not proper solution for my question. If I will use this workaround I need to change all informative screenshot of the activity. Can you please tell me the proper solution for this activity.
Fine
Thats really a good question @Arunachalam
I tried to reproduce your issue
and hope this would help you
–i had two projects Process_1 and Process_2, in each of the project i used to click activity to capture the informative screenshot with it
–Both in a separate folder
–Then i moved the Process_2 folder to Process_1
–and i tried to open the mail.xaml of Process_1, where i was able to see image in click activity
–here in the studio i opened the project panel and tried to expand the Process_2 folder as we have this moved to Process_1 folder
–in that expansion i tried to open the main.xaml with click activity but i was not able to see the image, as we are now in the Process_1 folder nupkg where all the screenshots image which are in the parent screenshot folder will only be visible,
–so as it terms parent screenshot folder i added the images from screenshot folder from Process_2 to Screenshot folder (parent folder) of Process_1
and i was able to see the image of Process_2 click activity being opened from Process_1 project folder
I think UiPath is developed to save the screenshots it in the parent folders only .
So, I’m suggesting you to do that manually by yourself using the existing activities.
And I just gave you an alternative to do the requirement than finding a solution from the Team UiPath .
