Hi @rameshgp43
Did u got the solution of Screen resolution setting? I want to contact you.
Is there any way to contact you?
Thanks
Alamgir
Hi @rameshgp43
Thanks
Alamgir
Did you get a solution of the mentioned issue. I am also facing the same issue, when running the BOT in unattended mode it is not working while it is working in obserbvation mode.
Hello,
i had a similar issue, the robot setting ālogin to consoleā can limit the screen resolution if set to true
Take into account that this setting is set both in the robot āsettingsā and in the āsettingsā file of the āserverā ( The UiPath.Settings
file is stored in the %ProgramData%\UiPath
folder.)
Hopefully the issue is this
Best regards
I faced similar issue earlier and it was resolved by following below -
ā āLoginToConsoleā: false - Robot Orch
ā āLoginToConsoleā: false, - UiPath.Setting
ā Check VM/RDP hardware configurations to allow higher resolutionā¦
In the bat file that you start with task scheduler type:
%homepath%\Downloads\QRes\QRes.exe /x:1689 /y:1050
This will change the resolution on the VM.
I tried almost everything and only that works fine for me and solved my problem.
