Hi Friends,
The calendar is as below:
The activity I am currently using:
The error will occur when there have same value in the calendar, making the bot do not know which to choose. For an example, Date_DateofDespatch used in 5/5/2022 is 5. However, May also is 5, so error will pop up. I tried to use F3: only selecting the region under May 2022 but it doesn’t work…Any suggestions?
Thank you!!
Hello @Low_Hua_Kuan
Is the month value and day value is same in the selector?? For example aaname=5 for both???
Could you compare both the selectors. There should be some attribue which separates both.
Better to use Uiexplorer and validate.
Hi @Rahul_Unnikrishnan,
Ya maybe the month value and day value is same in the selector, as I got activities before this to grab and compare the month and year value:
The activities screenshots are attached below:
The UiExplorer ss for month and year:
The Uiexplorer ss for date:
Thanks!
Is there any attribute tableCol in both selectors. If its different you can try that. Also if something constant in the selector you can replace with wildcard * as well
