Running uipath in a remote pc without internet connection
I am curious about, can we run UiPath automation in a remote pc which does not have an internet connection. I am currently using UiPath community edition and while using it in the offline mode it says: A local license is required
After some research I have found that offline license requires UiPath Enterprise so I am ready to buy it but before that can I get a brief information in how enterprise will solve my problem and also the pricing.
Thank you.
@gaurab7
Welcome to the community
When you buy enterprise license you can use offline as wel with no internet you might need to port all packages etc manually
For pricing its better you contact sales as it differs from regions and many other factors
@Anil_G Thanks!
Okay you mentioned about managing packages manually is there any materials how I can learn to do so and also how can I get to know about how to manage my packages to run offline is there any documentations.
Cheers !
@gaurab7
Either you have your own feed where you save the packages or install standalone orch and have it on the same machine and manage packages there
But if offline wherever new process is deployed you might need to move the .nupkg into the machine and then install
Basically you need to have a localfolder for all the pckages
@Anil_G Thank you for all the information means a lot.
Lastly, I have a concern about logs, will there be readable logs saved somewhere in offline mode so that I can use it to debug when necessary.
@gaurab7
Robots logs and studio loga would be saved yes…they would be in json format ..will little persing or a vacode you can read them properly
@Anil_G
I have one question,
Like if I have to run my project in remote pc via UiPath assistant using community version then which are the domains that needs to be whitelisted to run the project in the remote pc using orchestrator trigger.
You can’t use Community Commercially, so this is a none starter.
If you buy Enterprise and require whitelisting there is a page that lists all the endpoints to open up.
