Hi All,
I have a requirement where I have to run the activities even when system or VM is locked using Unattended BOT and Orchestrator. With Attended BOT it is working totally fine BUT it is not allowing the system to lock ,below are the specifications .
BOT ACIONS -
1- BOT is built to get the data from an internal web application
2- BOT is going on different 4 websites perform 4-6 clicks and Type actions handle few pop ups as well which are windows or JS popups.
Configurations -
1- VM with windows 10 for BOT execution
2- UIPATH Orchestrator
3- UIPATH Unattended BOT
if there is any step by step link available for enable the BOT workflow execution even if the screen remains lock that will be very helpful
Requesting urgent support
Thank you in Advance
