Robot Connection Problems with Orchestrator
Hello everyones, i have problems to connect the UiRobot with Orchestrator… The robot connect with Orchestrator but show that the robot is Unavailable in the status… and if y run a process will say that a robot with some name doesn’t exist in Orchestrator; but the robot exist…
Here is the image of the robot…
Robot%20Unavailable
Did you try to create a new and connect it?
Thanks,
Prankur
What is the messaged that is displayed if you hover over “Robot unavailable”?
I too faced similar kind of issue, I had the problem with the machine name (domain\username) provision part.
While doing provision it used to connect but when I tried to run process the bot was not available.
Resolution: go-to orchestrator and delete the existing bot and re-provison with proper names and try to connect again…
Hope this helps,
Thanks,
Meg
