Remove some parts of a string
Hello, I want to remove some parts of a string.
My string example is
And I want to remove all the “!” signs and have just only 1 left to build a table out of it and use the ! sign as separator.
Is there any simple solution to this?
Kind regards,
TPA
Hey!
Try like this
InputString.Replace("!"," ")
In generate data table give the separator as Space
NaNi
Hey
You can use this
StrVar. Replace(“!”, “”)
Thanks
Hi @Paul_Andrei_Turcu
Try this
NewString = System.Text.RegularExpressions.Regex.Replace(YourString, "!{2,}", "!")
