I currently have an issue - my colleague and i worked on a process together. Most parts of the development were done by my colleague and everything worked fine when testing was done on her system. Also, i tested the workflows on my system and things seemed to work fine, however, some activities like send hotkey did not function properly basically cos i use a MAC. I have switched to a windows system but now noticed that most of the activities that worked earlier aren’t working anymore. The click activities as well happen on random spots on the remote desktop screen instead of the actual selectors. In addition to this, the RDP looks like it has a different resolution on my Windows.
I want to request for my colleagues display settings for use to set up mine, hoping this works but just want to check if any other person has faced similar issue and how/if it was solved.
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
It depends upon which RDP tool you used. If you use RDP tools like logmein or R-HUB remote support servers, you will not face the remote desktop screen resolution problem.
