Remote Desktop issue
I. Athanaias
April 26, 2016 11:35 ANSWERED
Hi
have a your software running on a remote computer actually works wonderfully
except I disconnect the connection to the remote computer then does nothing what can be wrong might.
23:55:27.6957 Error {“message”:“Click : Desktop has been disconnected while performing UI actions.”,"
Can onyone help me.
Mihai Badita April 26, 2016 13:57
By design.
Disconnecting your session will make the workflow to run in Session 0. The Windows Session 0 has no UI therefore you will be able to execute only background automation after disconnecting.
The solution is to set it to run from the Scheduled Tasks with Run weather user is logged on or off option checked.
I. Athanaias April 26, 2016 23:29
Hello,
Thanks for the great tip. Have all read
but the system has the following error
{ “Message”: "UiPath.Broker \ r \ nSystem.Exception: UiRobot must be started as a service to execute a workflow interactive \ r \ n at UiPath.Broker.ExecutorManager.StartNewExecutor (Service Broker broker, String username, IntPtr user token, Guid internalCredId, Open session Info
Wanted UiRobot as a service does not install know but how. Maybe you have
again a great idea.
But still thank you for the first clue
Mihai Badita April 27, 2016 13:41
Ah, that’s a know limitation for Community Edition. The service is running only under your user.
