Hi I am facing issue while extracting some information from the Text using Regular Expression. I have attached sample text [attachment Moderated] and I want following information out of it,
Type Location Name for P : Example company 1, TN 38141
Type Location Name for D : Example company 2, CA 92551
Actv Date for P : 09/09/2020
Actv Date for D : 09/17/2020
BOL : 5028124
PCS : 48 PLT
Stop Ref. Number : 5028124
Thank you @Arpit_Kesharwani. This one is capturing whole information after ‘P’. I want separate information, for example for the second match I need below information using separate expressions,
BOL : 5028124
PCS : 48 PLT
Stop Ref. Number : 5028124.
And I need this kind of info for all the six matches.
And as per your Regex ‘(?<=P ).*’, it would capture only using single character ‘P’. Is it possible to get match using whole text like ‘Type P’. Because if there will be any other character ‘P’ anywhere in pdf it would break the result.
