Regex TEXT Body-help
Hi everyone can I get assistance please: I am reading an outlook email body:
This is the normal email before I use regex:
Then after regex-it’s suppose to close all the spaces since I do not want any spaces but it does not it still the same as the above after I had used the regex see what I am using:
‘APIEmail_body’ as the original outlook body want to change and close spaces on
Hi @Anelisa_Bolosha1
Try this
StringBody = System.Text.RegularExpressions.Regex.Replace(APIEmail_body, "\s+", " ")
Hope this helps😇
@Anelisa_Bolosha1
Add on… the regex you have written is also correct and it should work
check variables you are checking. StringBody variable should contain the text with replaced (2+spaces) with " "
This is sample input and output
result = System.Text.RegularExpressions.Regex.Match(yourString, “(\d+(?:.\d+)?)\s*\p{L}”).Groups(1).Value
Perfect thank you so much it worked.
:slight_smile:
