Great Job !! @Steven_McKeering
BR.
@Steven_McKeering : I need your help in Regex
I need to get next n lines along with Matching text
Sample Text
Invoice:
ABC
123
567
Some random data which I don’t want.
Expected output:
Invoice:
ABC
123
567
Please note the order of the text can be different as well as the data is not case sensitive.
Sample 2:
Metadat:
aaabb
dgffyf
qwet
Invoices:
123
456
abc
Expected output:
Metadat:
aaabb
dgffyf
qwet
Invoices:
123
456
abc
Welcome to the UiPath Community @Rohit_Kishor_Varadkar
Thanks for the SOP!
Please make a new/separate post and I promise you will have a fast answer from me or another member of this great community!
Great post! Helps a lot, liked and shared - thanks.
Hi Steve,
Thats a wonderful Post quite useful a lot.
Here is my query.
Raw Text
Short Description : Need a RegEx help
Issue : RegEx
Issue Type : Medium
Long Description : Is there a way to separate the content using RegEx
Short Description : Need a RegEx help 1
Issue : RegEx 1
Issue Type : Medium
Long Description : Is there a way to separate the content using RegEx 1
Short Description : Need a RegEx help 2
Issue : RegEx 2
Issue Type : Medium
Long Description : Is there a way to separate the content using RegEx 2
Short Description : Need a RegEx help 3
Issue : RegEx 3
Issue Type : Medium
Long Description : Is there a way to separate the content using RegEx 3
Output
Output 1. Short Description : Need a RegEx help
Issue : RegEx
Issue Type : Medium
Output 2.Short Description : Need a RegEx help 1
Issue : RegEx 1
Issue Type : Medium
Output 3.Short Description : Need a RegEx help 2
Issue : RegEx 2
Issue Type : Medium
Output 4.Short Description : Need a RegEx help 3
Issue : RegEx 3
Issue Type : Medium
Pattern
The Label Names are always constant and will appear always in the file. “Short Description” is the field which I need to use to separate the content into multiple outputs depending on the content. Sometimes the content will have only one short description, next time it will appear more than once, so dynamically I need to identify how many times the word “Short Description” appears and accordingly i need to separate the content into that many outputs. Please advise.
Thanks for your post.
Do you mind creating a new post. I am sure you will have a response very fast
Yes Sure. Steve.
