Read SMTP and download attachments problem
Dear all,
recently i encountered a problem with reading SMTP mail and download attachments. Background: we are not using outlook so any outlook activities cannot be used.
As you can see from the following screen shots. This is a message that i got forwarded from our external supplier. However, when i try to read the “sender”, “main body” and try to download the attachments from it, UiPath returns errors
Sender -> object reference not set to an instance of an object
Main body -> empty
Attachments -> no attachments found
And when i try to forward the email using send SMTP message. Only a part of the email will be forwarded. However, if i try it manual, the whole message with the attachments are forwarded correctly.
I’m wondering whether anyone has come across the same problem and can help me out. thanks a lot!
Dong
@ya_dong
check whether its geting mail with attachment or not
use a writeline activity and mention like this inside the for each loop activity
#Mail.Attachments.Any.ToString#
If its true then its wrking fine
Dear Nikhil, please read my post. no attachments can be found although there are attachments.
@ya_dong
Can you refer this post
This type of Problem might occur , Hope this helps
