Read Selected Column From Excel and split using LINQ
Hi ,
I have a huge excel from which I need to select specific columns with Alias Name and also split a columns. Can this be done with Linq queries
COLUMN A COLUMN B COLUMN C
TEST TEST01 999999 Not Required
I need COLUMN A (Split by space) with Alias Name XXX and YYY and Column B with Alias Name GGG
XXX YYYY GGG
TEST TEST01 999999
Thanks in advance
Hi Nimesh,
You can achieve this by using LINQ.
Can you try this code block in Invoke Code activity:
(You must set the property to C#)
    result.Columns.Add("XXX", typeof(string));
    result.Columns.Add("YYYY", typeof(string));
    result.Columns.Add("GGG", typeof(string));
    // Convert DataTable using LINQ
    foreach (DataRow row in dataTable.AsEnumerable())
        string[] splitColumnA = row.Field<string>("Column A").Split(' ');
        DataRow newRow = result.NewRow();
        newRow["XXX"] = splitColumnA.Length > 0 ? splitColumnA[0] : "";
        newRow["YYYY"] = splitColumnA.Length > 1 ? splitColumnA[1] : "";
        newRow["GGG"] = row.Field<string>("Column B");
        result.Rows.Add(newRow);
    // Print result
    foreach (DataRow row in result.Rows)
        Console.WriteLine($"{row["XXX"]}\t{row["YYYY"]}\t{row["GGG"]}");
You can also find the workflow attached:
Sequence.zip (2.2 KB)
Kind Regards,
Kardelen
Thanks a lot. Will try the same and update you.
Hi @nimesh2382
=> Build Data Table
Output-> newDt
=> Read Range Workbook
Output-> dt
=> Use below syntax in Assign activity:
newDt = (From row In dt.AsEnumerable()
         Let splitValues = row.Field(Of String)("COLUMN A").Split(" "c)
         Select newDt.Rows.Add(splitValues(0), If(splitValues.Length > 1, splitValues(1), Nothing), row.Field(Of Double)("COLUMN B"))).CopyToDataTable()
=> Write Range Workbook newDt back to excel
Sequence9.xaml (10.6 KB)
Hope it helps!!
Thanks a lot for your help…Yes this also works
