Read range of particular row in excel 1 pas data form excel 2 ,Data not past perfect data, i need result in with percentages words correct format
Excel 1 Excel2Weekly Performance-Template.xlsx (11.8 KB) Coders weekly status.xlsx (11.2 KB)
Can you explain the question with little bit more detailed? @damodar99
Thank You :slight_smile:
readExcelFirstRow.zip (27.4 KB)
Please find the attached file. Confirm me if it works and mark as resolved
Read range of particular row in excel 1 pas data form excel 2 ,Data not past perfect data, i need result in with percentages words correct format , attached the excel sheets
Hi @damodar99
What ever data you are writing to another excel just append the percentile sign to it.
YourVariableInWhichDataIsStored+“%”
Mark as solution and like it if this helps you :slight_smile:
Happy Automation :raised_hands:
Best Regards
Er Pratik Wavhal :robot::man_technologist:t4: :computer:
@damodar99,
Could you elaborate on the issue you’re facing, and explain what you’ve tried?
Please look at the Forum FAQ and try reposting this topic or edit the original post, so people can help you better:
am written like Ex: Test.tostring +“%” but not getting % prefer result, plz help out
