Read Range is not showing in Activities section
Read Range is not showing in Activities section when i try to search in UI Path Studio pro community, Can you please guide me on this
@Aje_A-Z
Welcome to forums
Check if you have installed UiPath.Excel.Actvities package from Manage packages?
If not, then install it and you will able to see Read Range activity
Hope this may help you
Thanks
Hi @Aje_A-Z,
I think I had a similar issue to this a while back:
I’d check the filter in the activities pane:
And check that the package sources in the Manage Packages > Settings window are all checked:
Hope this helps! :slight_smile:
I able to see read range after installed UiPath.Excel.Activities.
Thanks for your support
Hi @Aje_A-Z,
Please mark @Srini84’s response as the solution to close the post :slight_smile:
See this if you’re stuck: How to mark solution in Uipath Forum - #4 by lakshman
