I need to extract the data from column ‘H’
Test to change the range to “H:H” instead.
now when I try to insert the excel extract to the field in SAP I have this result
can you give me a hint how to fix this error
Hello @pauloengenharia5
You can use Read range activity and in the range provide the starting cell name, H7
Also SAp field accepts set of values or value one by one.
You can try convert the data table to string using output data table activity, then write that variable to the SAP field.
Thanks
Test to use For Each Row on data table and then Type Into in the loop.
