the name of the sheet of excel is correct i run my bot a few moments ago but in this moment i cant to read the range
Hi @VAZQUEZ_SOSA_LUIS_ALBERTO ,
If you are reading only one cell value from excel use read cell activity in uipath instead of read range. Thanks.
It seems that you are using Excel Application Scope to read Excel file. You may check whether there is any Excel process running in backend (Run Task Manager to check). You can kill the Excel process if there is any.
Another way to read Excel data is using Read Range under Workbook, which runs in backend and is faster than using Excel Application Scope.
the error is in this part
i have to change 3000 to 4000 because my excel have more 3000 records
