Read range and create a variable with it
Hello,
I am searching a way to : read an excel cell (or Datatable), it contains a selector id that i have to store on a variable.
My goal is to click on a button in a website then perform a certain action.
Then do the same action with another button ( the selector will then change with the variable)
So i have already stored the id on a DataTable but i want read the first line which contains the first selector id.
I am new to uipath so i dont know if this is the right way to perform this action.
Thanks for your advice
@zSmiley Welcome in community.
Can you show me excel file template?, So i can suggest something to you.
I am getting your problem its minor issue which can be be solve by giving range
Hello @zSmiley
Here the motive is to make the selector dynamic. so you can loop through each row and get that row to a variable and then pass it as a dynamic variable to the selector.
Can watch the below video to understand the dynamic selector in better.
Hello,
I am sure this is pretty easy, but i feel like im missing a little step.
So I have many customers with their login and pass and I have to go download the same data, the only different is that the number of file is not the same so i used a find children to get the number to loop and the cursor id.
And i get
So my goal now is to loop with them.
So i want to Create a variable with the Range A&“number” (number will be 1 and at the end of the loop i will add +1)
When i try to read range it tell me that there is a problem with converting String to UiPath.Excel.IReadRangeRef.
I dont know if my approach is the right one.
Thanks in advance
Hi @zSmiley
Can you elaborate you query little bit? And share some sample input file with us.
Regards
Gokul
Hello,
I finally find the solution it was the read range that was not well configured, it finally worked.
Have a nice day
