While searching in all package section remove all the filters that already. Click on filter icon where it showing 6 filters, remove those filters and search there you can find the ocr package.
And according your issue go project dependencies there repair your packages where it showing any error.
Thank you, @yedukondaluaregala! Removing all the filters fixed the issue. The OCR packages are now visible, and my problem is resolved.
Thanks for your support!
Thanks! @Anil_G The issue is resolved now. It was caused by the filters enabled in Manage Packages. After removing them, the package became visible. Appreciate your help!
