ch460960
(Ch460960)
1
Hi Team,
I fetched the data from database and stored in Datable Named Output variable.
I need to read Grand Total and Sum_Invoice_TA as shown in picture.
I used: Output.Rows(1)(“Grand_Total”).toString=Output.Rows(2)(“SUM_Invoice_TA”).toString
It gives me error there is no row at position 1 .
can anyone please help. Thanks in advance
Hi @ch460960
Could you try this instead?
Output.Rows(0)(“Grand_Total”).toString=Output.Rows(0)(“SUM_Invoice_TA”).toString
Kind Regards,
Ashwin A.K
ppr
(Peter)
4
row indexes are 0 based.
we do understand that from 2nd row a value has to be assigned to a first row
Output.Rows(0)(“Grand_Total”).toString=Output.Rows(1)(“SUM_Invoice_TA”).toString
But when exception is about no row on position then you will have maybe only 1 or 0 row. So just inpoect the datatable e.g while debugging
in case of only 1 row is present then refer to Ashwins post from above
system
(system)
Closed
5
