Read Column Excel Integration, variable as range does not working
Hi everyone,
I am trying to read columns from a sheet and save it in an output variable. But I am trying to have the input range as a variable, instead of having “A:A” I want to have “rangeStart:rangeEnd” with both variables having as value the letter A and being strings.
When I try to debug the file, in that part, an output appears saying “The range does not exist” but if I type “A:A” it runs smoothly. The problems is that the column letter may vary that is why I need a variable instead
Thank you in advanced,
Can you try the following expression?
rangeStart+":"+rangeEnd
or
rangeStart.ToString+":"+rangeEnd.ToString
Hi Yoichi,
That really work, I didn’t think of putting double quotes for the “:”
Thank you
