Raname "body"/"sequence" scope in studio 23.10
When I use a “for each”/if/“else if” activity studio automatically creates a sequence/scope. In previous versions of studio I could rename this sequence to something more meaningful, which helped with readability.
Since We updated to studio version 23.10.7 it seems I can’t rename these automaticly created sequences anymore. This can sometimes be confusing when I want to check/change the scope of a variable since I sometimes get multiple scopes named “body” or “Sequence”.
Is there still a way I can rename these scopes?
kind regards,
Jelle
Hi @jelle.segers.Bpost
Right click on the xaml and edit with notepad and make the changes
Try this!
Hope this helps!
@jelle.segers.Bpost,
As far as I know, there is no option to rename it.
Thank you for the response.
In the xaml file I can indeed change the name of the sequence
This changes the name of the scope in the variable pane, so in the cases where it becomes a real issue I can use this.
But:
  • I hoped there would be a solution where I wouldn’t have to search in the xaml directly.
  • The display name is only used to name the scope, and is not shown in the activity itself '-> we can get a mismatch in names.
I hoped there was a solution that’s close to how it was shown in previous versions of studio. But I fear it’s not possible.
@jelle.segers.Bpost
Where exactly are you seeing the issue…we are able to rename
on 24.10 though
cheers
