I want to run run code through tray icon after publishing it.
So do i need the code should present on same machine.
I am using RE-Framework Template & Project Folder structure.
Hi @kalv,
When your Robot (Uirobot.exe) is connected to Orchestrator and now when you publish the code. No need of code should present in the same machine but When you publish the code without connecting bot to Orchestrator then You need to have code in the same machine.
