Project Settings features - UiPath Studio 2019.10.1
In this topic,let us look into the Project Settings features that are available with the UiPath Studio release 2019.10.1
The Project Settings now allows us to set defaults for the activities at a project level, which helps with faster implementations and a standard global setting of the most commonly used activities in the project.
The Activities can be set for System, Computer Vision, OCR and UI Automation.
Example:
For a web based application we quite frequently use the activities Attach Browser or Open Browser and it is quite common that we miss out selecting the “BrowserType” every time we use this activity.
We can now set this up in the “Project Settings – UI Automation” and forget about setting them within each Attach / Open Browser activity that is added to the workflow.
Commonly used mouse events such as Simulate Click, Send Windows Messages can also be set up here (Under Project Settings – UI Automation – Mouse Events).
Apart from this, the ability to set debug values (that can be used for development and testing) and production values (that can be used in the live environment) is also available.
A Bulk Action feature is also available to copy production settings to debug and vice versa and also to reset them.
Awesome
Cheers @SowmyaLeo
Thanks @Palaniyappan
Good job @SowmyaLeo
Thanks @lakshman
Wonderful to know default properties of activities can be customized as per project.
Thank you @SowmyaLeo
Thanks @Mahesh_Gunda
Wow your great @SowmyaLeo keep going and rocking our community :smiley:
cheers :smiley:
Happy learning :smiley:
Thank you @pattyricarte
:slight_smile:
Thanks for sharing this article.
Thank you @rathrolla
Helpful :slight_smile:
Thank you @mukeshkala :slight_smile:
Cool @SowmyaLeo :smiley:
Good Job Sowmya
Thank you @Gemlan
Thank you @Theepan
Thank you … :slightly_smiling_face:
How do you indicate which environment you are in? Is the fact that you “run” compared to “debug” all you need to do?
