Project running in PiP machine
Hi Members,
Whenever I am running any program or project on my UiPath Studio it is running in PiP mode only, just like a virtual machine. Not in the usual way. For reference check the screenshot:
Even though sometimes it gets into timeout error also, for that I have changed the environment variable using these docs: Picture In Picture
But overall I want my projects and programs to run in the usual way, not in PiP mode or on a VM.
Appreciate an early response and solution for the same.
Thanks,
Taruna
is it unselected?
Just go to DEBUG Menu, then Deactivate “Picture in Picture” (Should not in Grey Color)
hi,
Its sorted thanks
