Project Published but not saved in System…
so please let me know how to save in system
Hi Buddy @badal_patel its simple
Follow these steps so it gets saved in local feed
Just like how you published to orchestrator
click on publish button
Next Select Publish Option – Give it as local feed
and click publish
Hello @badal_patel ,
There are two ways of Publishing.
To Orchestrator: Publish to Orchestrator- You have to choose Orchestrator Tenant or Orchestrator personal
To Local: Choose Custom and select the folder where you need to Save.
@badal_patel You can download the packages using two ways
Approach 1 : You can save the package to your local folder as mentioned by the few folks in the above posts
Approach 2: You can also download from the Orchestrator itself
- Login to your Orchesatrtor
- Go Packages tab within Tenant
- Search for the package that you are looking for. Click on the three dots at the end and choose View Version
- Now, click on the three dots at the version and choose download package
Ref below doc
