Project problem
I have a zip file in zipfile there was a many different pdf i want move matching pdf in each folders …
@Shabby03
I suggest, that you use varDirectory.GetFiles(“Folder path”) store it in a variable, than use for each loop, and check if the folder name matchs the names you want and use move file acitivity.
