Process Mining Dapr Container Crahsbackloopoff Due To Certificates Expired And Not Automatically Rotated
The end-user is unable to access the application frontend after performing an OS patch upgrade on their servers. The error message displayed is: '"Failed to initialize the application"'. Additionally, warnings were observed on the ArgoCD side and attempts to Sync/Refresh the services did not resolve the issue.
Issue description:
Failed to initialize the application Process Mining - error no healthy stream.
In Process Mining pod description the certificates issued by dapr.io app appear as expired.
Resolution:
On the main Linux node perform the following commands:
sudo su
export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin” && export KUBECONFIG="/etc/rancher/rke2/rke2.yaml"
vi clear-trust-bundle-dapr.yaml ------ the yaml file is a the bottom of this kb
kubectl -n uipath apply -f clear-trust-bundle-dapr.yaml
kubectl rollout restart -n uipath deployment/dapr-sentry
kubectl rollout restart deploy/dapr-operator -n uipath
kubectl rollout restart deploy/dapr-sidecar-injector -n uipath
kubectl rollout restart deploy/dapr-scheduler-server -n uipath
kubectl -n uipath get pods -w | grep dapr ----- wait to raise the pods ( 3 - 4 mins )
kubectl rollout restart -n uipath deployment process-mining process-mining-dbt-exec process-mining-frontend
kubectl -n uipath get pods -w | grep process ----- wait to raise the pods ( 3 - 4 mins )
clear-trust-bundle-dapr.yaml :
apiVersion: v1
kind: Secret
metadata:
labels:
app: dapr-sentry
data:
