Process getting faulted while running in Orchestartor but the same process succefully running in UiPath Studio(Manually)
Hello,
I am getting successful execution when I run the processes in UiPath studio (Manually), but when i run the same process with same version and same BOT in Orchestrator, i am getting error as “Object reference not set to an instance of an object”.
Please help me on this.
Cheers!
Kumar.
@skaruppanakumar
Usually Object Reference error will appear if the bot is getting any null value.
So check in which activity you are facing that issue
Also check if you have passed any value which is not accessible by the bot machine
Hope this may help you
Thanks
Thanks for the quick reply!
Will check Srini!
Cheers!
Kumar.
