Problems when executing work does not run
I need help? I am executing a job from the orchestrator, but it seems that it is running da success but I never see it running on my PC
Hi @jsuarezs
Have you linked your machine to the orchestrator properly? I guess you have not linked another computer?
What kind of a process are you running? I mean what does it do? When executing, do you see the robot executor icon on the task bar? Ui logo on a white background icon
@jsuarezs
Could you please check logs of that job once.
Yes, I have linked the machine to the orchestrator, but when I launch the process since the Job changes its state, it goes from hanging to sucesss but nothing is executed, regardless of whether it is a simple or difficult flow
When running does it show the robot executor on the task bar?
yes, I can see in the orchestrator that is running but in the VM I can’t see the robot running
and from the same machine if I run it from Uipath Roobt the Robot doesn’t run either
@jsuarezs
Then some problem with your Robot process only. Are you able to run the same process from UiPath studio ?
desde] Uipath studio si ejecutado perfectamente pero de uipath Robot no se ejcuta
hi @jsuarezs
Check the uirobot service
Thanks
Ashwin.S
Hello, I’m having the same problem. Any solution?
Hi
Can you guys check whether the robot service is running in the task manager?
Try to change the log level to verbose and then look at the logs you will get all the information like how which activity is getting error’s.
