Problems in publishing a project
Hello friends,
I have a Bot running from a UiPath Robot on a Virtual Machine.
After an unexpected shut down of the Virtual Machine, the Robot doesn’t have any process available.
I tried republishing the Bot but it gives this error.
and this log
Can anyone tell me which one is the problem?
I don’t know how to solve this problem.
Thank you so much,
Camilla .)
Hi @CamiCat,
Can you please verify the parameters which is having the invokeworkflow …
Regards
Balamurugan
do debug the code , and also keep try catch write the exception then we can find it out easily
Thank you so much @balupad14.
I’ll have a look and let you know as soon as possible.
Camilla :relaxed::relaxed:
